04 monte carlo
any ideas on an 04 monte carlo or if anyone has seen anything good with it. i know the little place under the radio, but i dont think i could fit a scanner/ radio into it. any suggestions
Fort Wayne, IN
That is tricky...I used to have an 04 Monte Carlo but i never had any radios in it; that was before I picked up this hobby. You could try on the side of the center console maybe. That's the only place I can think of unless you can cut that cubbyhole out from underneath the radio
fireSAR
third rock from the sun
as posted many times before, we need a picture of the interior. Because right now it escapes me to what it looks like in a 04 Monte Carlo.
i knew that was coming. when i get my digital camera working ill get some pics up
Fort Wayne, IN
helps that i used to have one. I know exactly what it looks like. and i stand by my suggestion unless you can rig something up underneath the glove box. If you can get one small enough you might be able to get it under the dash on the driver's side but that would have to be pretty thin.
any chance with putting in a 996 like actually installing it not just sticking it in somewhere
Fort Wayne, IN
Are you talking about an in-dash install? Cause if so then probably not. If you put it under the glove box or dash or on either side of the console then you will have fairly easy access to power. Another thing to consider is to get one of those remote faceplates for it; I noticed that Uniden makes those for the Bearcats. That way you can keep the main radio under the seat and then put the face just about anywhere you want.
