Here was the old setup:
http://www.radioreference.com/forums/pictures-your-shack-mobile-setup/105263-05-impala-install.html
I have re-worked my Impala. I mounted the Sirius radio with a mount from mountguys.com. I attached it to the bottom side of my scanner. The Garmin GPS is attached to the side of my scanner with the OEM stuff that came with it. The Garmin GPS came with two mounts(suction cup and bean bag) and two power plugs(both for cars), good deal! The Blackberry mount came from mountguys also. All the mount are universal so I can swap them around from position to position if I have to. The speaker above the drivers seat is tied to the scanner. The speaker below the tied into the TM-D700a. GPS for the TM-D700a is hidden in the dash.
I'm still waiting for my bluetooth equipment, head mount for my TM-D700a, and timer to come in. The timer will be tied into everything and will shut it off after a pre-set time has passed after the key is turned off.
The girlfriend hasn't seen it yet, but I'm sure I will get the head shake. She won't drive my car anymore with the speaker above the drivers seat.
