1/4 Wave 20 Meter Antenna to 5/8 CB Base
Biggie_Z
Winters, CA
I have have a MFJ-1979 antenna which is a 17' 20 meter full 1/4 wave stainless steel antenna. I want to convert it to a 5/8 wave CB base antenna since I now have a better antenna for 20 meter use. I calculated a 5/8 wave antenna in the middle of the band would be 21.5'. Would this endeavor be as simple as adding another 4.5 foot stainless steel section to the bottom of the antenna? The whip has a standard 3/8" stud on the bottom so I could easily fabricate this. Any advice would be greatly appreciated, thanks.
You'd need some impedance matching in the base. A 5/8th's wave antenna does not have the 50Ω impedance that a 1/4 wave does.
