1/4 wave stubby Vs 1/4 wave mobile antenna
Peoria, IL
Good evening I wanted to know what would have better range on a radio. I wanted to know becasue I use a 1/4 wave stubby and I thought of buying a 1/4 wave mobile antenna instead of the stubby. It is for UHF. Could someone help me out please.
Thank you
jaspence
Michigan
Stubby vs mobile
The 1/4 wave mobile is designed to work with a ground plane. A stubby for a HT is not much more than a tuned(?) dummy load and requires no ground plane. I have seen a quarter wave used on a HT with a piece of wire for the counterpoise or ground plane. Since you are using UHF, there are many HT antennas that will give better performance than a stubby without any additional wire or ground. Whip antenna - Wikipedia, the free encyclopedia gives a good explanation of the antenna gain.
ff-medic
Banned
The Appalachians - Next to the tent and campfire.
Thank you
I like the antennas with the load in the center = Amazon.com: Browning BR-450 UHF Land Mobile Base Antenna: Electronics
However the antenna may not be exact ( I googled and googled ) it gives you an idea.
FF - Medic !!!
ko6jw_2
Santa Ynez, CA
Consider an analogy to a camera lens. The larger the aperture of the lens the more light gathering power it has. A physically larger resonant antenna will deliver more signal to the radio. A stubby antenna can be made resonant, but it will not be as efficient. The ground plane is a consideration. On a hand held radio your body and the body of the radio are the ground plane. This is not as effective as a real ground plane. At UHF frequencies it is practical to use 1/2 wave antennas since they are relatively short (say about 12 inches). A half wave antenna does not require a ground plane. It will require an impedance matching coil, but will be quite efficient.
