1 power supply for 2 radios, how to?
Danny37
New York City
So I have two vertex vx-4207 mobile radios that I use as scanners. One has been collecting dust in storage for a while so I thought I should I hook it up. There's no transmitting on these radios as they are used specifically for receiving purposes only. I have a 10 amp supply for one of them and I'm clueless on how I should hook up the second one. Is it safe? Do I need to buy fuses for the 2nd radio? (The one I use currently has fuses) is there a spiltter of some sort to split the power? links for products (preferably on Amazon) would be really appreciate.
Thanks in advance
parma,ohio
i use a Astron 10 AMP on all 3 Motorola radios for base use only TX on 1 radio all 3 have the Motorola Power Cables i just hooked all 3 to the Power Terminal on the rear of the Power Supply.
jwt873
Woodlands, Manitoba
There shouldn't be a problem. Hook them up in parallel. Connect the plus lead from each radio to the plus terminal on the supply and the negative lead from each radio to the negative terminal on the supply.
You won't need to by fuses for the second radio, but it's good practice to have fuses.
Danny37
New York City
So bare wire from both radios making contact with each other won't do any damage to radios or the power supply when I connect them to the leads?
KevinC
The big K
Super Moderator
1 point
Posts deleted. If you don't plan on helping then please don't reply. Thank you!
AK9R
Super Moderator
Central Indiana
Thread moved. The OP isn't using amateur radio equipment and his question has more to do with radio installation than it does amateur radio.
Yes, it's safe as long as you properly fuse the radios.
Strongly recommended, however there are multiple ways to do this, see below:
Sure, Something like this would work:
https://www.amazon.com/Seachoice-AT...F8&qid=1514570851&sr=8-43&keywords=fuse+block
It allows you to fuse each radio individually as well as provides a connection point for the negative leads. I've used similar fuse blocks on installs, and they work well.
k6cpo
San Diego, CA
This fuse block doesn't make accommodation for the negative return lead. That would have to be a separate piece.
Something like one of the fused RigRunners mentioned above would be a better approach. Here's the setup I use in my shack:
The lead on the left to the 40A fuse comes from the power supply. The other three leads, each fused at 25A got to a 2m/70cm mobile, a 6m mobile and an iCom HF radio. The only issue with using something like this is that it requires the ability to install Anderson Powerpoles on all the leads.
737mech
Clark County, NV.
power supply
I currently run two switcher power supplies to power my scanners. One is sec1212 powers two bct-15X's, a psr-410 and a pro-2042. The second powers three scanners bct-15/ pro-2051 and bcd-536hp that power supply is repurposed from an old motorola repeater. I installed volt meters on both and have had zero problems for a few years now. You can see the volt meters 13.9 and 13.7. I really like those rigrunner modules! Looking into them now!!
scanmanmi
Central Michigan
Mine hasn't caught fire yet.
picture.php
