106 scanning 3 scanlists
N8IAA
Fortunately, GA
Ok, really new to the 106, just had it a month. Wanted to see the CC info for different systems I have programmed in the scanner. Did the F2/F3. Somewhere in doing this, pushed the FUNC key and have ScanList 1,2 and 9 scanning when ScanList 1 is scanning. What did I do, and how do I get it back to scanning individual lists again?
TIA,
Larry
Forts
Ontario, Canada
Wait.... what? You hit the 1 button to enable scanlist one and it turns on 3 lists?
Forts
Ontario, Canada
Have you programmed it all by hand or are you using any software? Software is nice in the sense that it sort of lets you take a step back and see a broader picture of how you have things programmed.
Not sure how in the world you get 3 scan lists to turn on via 1 button. Can you still toggle the other lists on and off manually?
N8IAA
Fortunately, GA
Normally, I use Win500 to program the radio. This was done via the keyboard. I know that it worked great when I first did my county's P25 system. Then I tried the next county over system. It show analyz when pushing the F2 key and then the F3 key. Worked great. Then I did my county's old system that the city PD's are on, and that's when I pushed the F2 key then pushed the FUNC key. Then Scanlist 1,2, and 9 were scanning. I certainly have cornfused myself on this one. Now, I can't get it to stop:p
Larry
N8IAA
Fortunately, GA
3 scanlists scanning from the first scanlist on 106
This is what I should have made the topic to begin with.
Larry
N8IAA
Fortunately, GA
Open Win500 and send file back to scanner. Then toggle whatever scanlist you desire to scan.
Frank, what did I do to make this happen so I don't do it again:) * Oh, I did send the file back, but it is still doing it. *
Larry
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Larry
Cant help with this issue because Like Forts, I could not duplicate the problem. Pressing FUNC as you described during analys only caused the F to release with beep when pressing any number on keyboard.
N8IAA
Fortunately, GA
Got rid of my wildcard selections for the 3 systems that I wanted to search for new TGID's. Now when scanning list 1, no more scanning of the other 2 lists.
Larry
