1090.00 Mhz
dcr_inc
Not an EXPERT !!
Delta, Pa
Is it possible to program 1090.00 Mhz to receive ADSB signals?
mikev
Northern VA
This might be better asked in the Aircraft Monitoring forum.
But to answer your question, I would imagine that if the scanner can receive the frequency, you can program it in. However, the scanner won't decode the signal into data you can use on your computer.
You would be better suited looking for a dedicated ADSB receiver to receive and decode the data.
dcr_inc
Not an EXPERT !!
Delta, Pa
I posted it here because the scanner will not allow you to enter the 1090 MHz frequency because it is NOT in the USA band plan.. How do I trick this scanner to allow it?
I know I need a decoder to decode the data
dcr_inc
Not an EXPERT !!
Delta, Pa
PSR 800.. I did figure how to Service Search from 960 to 1240 but I want to be able to scan 1090 just like any other freq
