1095 help
firecatohio
Logan, oh
Just received my 1095. Did firmware/library/etc update on pc... got hooked up with new antenna. Not receiving anything.. I miss something?
Sent from my SM-N920V using Tapatalk
troymail
Silent Key
In Franklin County at the moment... have fire in it
Still not much to work with --
Looking at the Franklin County page: Franklin County, Ohio (OH) Scanner Frequencies and Radio Frequency Reference
this system: Franklin County Public Safety Trunking System, Columbus, Ohio - Scanner Frequencies appears to be obsolete.
it looks like they are on the state system Ohio MARCS-IP: Multi-Agency Radio Communications (P25) Trunking System, Various, Ohio - Scanner Frequencies
which has many, many sites - and as many as 5-7 in Franklin County.
You probably only want to program the closest site to you location - but that's not 100%
So what did you program and did you use the EZ Scan PC software (and copy that configuration to your scanner) - or - did you do programming via the radio itself?
firecatohio
Logan, oh
After doing the updates I now go to select area, then county.. after doing that I hit scan and it says nothing to play
wbswetnam
DMR-istan
What service types did you select? Fire dispatch and fire tac?
wbswetnam
DMR-istan
If you have selected those service types, and you have properly loaded the database into scan lists, then it should play correctly. Personally I prefer setting up scan lists through the iScan software, so I can adjust the channel names and other settings. I have the WS 1095 in my car, mounted on the side of the central console.
