12/25 cable
RRR
OFFLINE
USA
Hello,
Will a Motorola 12/25 programming cable also work on an XPR2550?
I only have -1- to program, and rather not buy the cable if what I already have will suffice. I don't want to experiment with it, as I don't want to rish bricking the radio.
Thanks in advance
RRR
OFFLINE
USA
You are correct, I should have typed 2500
K2NEC
5F6
Gotcha. Refresh my memory, does the 1225 have a RIB?
  • Like
Reactions: RRR
RRR
OFFLINE
USA
It does not. USB from laptop to the "cat" type connection (similar to Kenwood mobiles)
K2NEC
5F6
Well you wont brick the radio if you try. If it works then it works, if not, you will get a communication error
RRR
OFFLINE
USA
Hello,
Will a Motorola 12/25 programming cable also work on an XPR-2500?
N4KVE
PALM BEACH, FLORIDA
You can program your 2500 through the rear acc connector. The plug, & pin kit comes with every new radio in the box. Grab a printer cable, & cut off the printer plug. It took me 5 minutes to make one.
  • Like
Reactions: RRR
RRR
OFFLINE
USA
I was hoping I could program it through the MIC. port. It is mounted in a vehicle, and I would have to remove it to get to the rear, and in it's current position, would be rather difficult.
N4KVE
PALM BEACH, FLORIDA
Understood. I’m in a similar situation, but I attached the cable as I did the radio install, so it’s permanently in the car. This way, I don’t have to unplug the mike when I program the radio.
  • Like
Reactions: RRR
RRR
OFFLINE
USA
Yea, it's not mine, but I have a HHCH on my 5550, and I ran the printer cable from the rear where the radio is, up to the cabin, so I could program it without having to move stuff to access the radio.
If I had a fleet of 2500's, I would just get the cable, but it's just one truck, he likes it, and wants to keep it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
It does program through the mic port. You'll need a PMKN4147A cable. Runs about $30.
RRR
OFFLINE
USA
10-4, I was hoping the 12/25 cable would be the same. I will have to drive to the guy with the radio
