12.5 kHz error
dixie729
Daviess Co., KY
Using R06.12.08 to program CDM1550.
This is what I got when I went to write.
All my personalities are on 12.5 kHz
Why am I getting this message?
Tech792
Central NJ
Newer CPS versions won't program any 25 khz freqs (wideband). Only 12.5 narrow band (unless you obtain a key from Motorola)
cabletech
Puget Sound
The pop up message that you received about 12.5kz, is built into the program to remind you that only 12.5kz frequency's can be programed unless you have "unlocked" the program with keys that you have to get from Motorola.
No big deal. Just click okay and keep going.
If you are trying wide band frequency's like ham, then you need to key.
In picture on the right, as for txdpl codes, they are default codes and you can change them as needed. Just remember that if you do not need a code, the highlite it, press enter the select off or none.
SteveC0625
Northville, NY (Fulton County)
We've discussed this a few times already. You need to go into the LS or LTR Trunking section and set all the active repeaters to 12.5. If all of your conventional personalities are already 12.5, you should be then able to write to the radio with no problem.
(If you are not using LTR at all, you should only have one repeater checked as it won't let you zero that are out completely. Make sure that one is 12.5.)
That little problem is invisible to those of us who have the 20/25 KHz EID installed, but without that EID, it will appear every time for every codeplug.
zz0468
Banned
Went back to R06.12.05
Sometimes that's the right thing to do. I've long been leery of CPS upgrades, and prefer to have an understanding of just what they do before I load them and actually write to a radio with it.
