1225 programming software on Windows7
kdolsen911
Hayti, SD
Is there any way or newer version of 1225 programming software that will run on windows 7? Mine will only work on windows XP. Thanks
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
I just went through this same issue here. I don't believe there is a solution unless you can get the Virtual XP and run that on your Win 7 machine. Even then it may not work.
Since the 1225's are no longer made, it is doubtful that there will be any upgrades to the CPS.
Someone else may have newer or better info, but I have not heard of any solutions.
n3obl
Ø
PA
The xp version will work but you have to do the install in compability mode and also run as admin. Find the setup file when you install and right click to bring up the properites tab and click then find compability.
SteveC0625
Tried that and I still get the same error message; incompatible with my version of Win 7. Thoughts?
