12V battery on Charger vs 12V Regulated Power Supply
jaytoddmartin
Loogootee, IN
Would there ever be an advantage to using a 750CCA battery connected to a charger to power a mobile rig/amp vs using a 20amp regulated power supply?
I can't kick the thought out of my mind. Maybe I just get excited thinking about the trickle charger display changing.
Thanks for all discussion on the topic.
Jay
ka3aaa
middletown, pa.
the only advantage is whenever or if the utility power would go down you would have power to operate the radios.
LATA 722
It's a good option if you are in a location that loses power frequently.
You need to do it carefully, though. If you want it to work well, you need to have the right equipment and it needs to be set up correctly.
You would need to set the voltage output from the regulated power supply to whatever the manufacturer designated float voltage is for the battery. That will keep the battery topped off, but not over charge it. Ideally you want some isolation so the battery doesn't discharge back into the power supply, that can be done with a large diode, or a specifically built battery isolator. Using an automotive battery charger can be an issue as they are designed to quickly charge the battery. You'd want it to be a multi stage charger that will go back to a float charge once the battery is full. You'd also want to be careful with the amount of RF noise generated by the charger. Some of them can be pretty noisy.
If this is a car battery, you need to be really careful as they are designed for automotive use. Having them inside your home needs to be done carefully as they can outgas hydrogen when charging. Ideally you want it outside or at least in an enclosure with a vent outdoors.
Gel cells are a better option, if you have one. A bit less dangerous and designed for use indoors. They also make power supplies designed for communications use that have a battery revert option. These have a circuit that will keep a gel cell battery charged and power the radios. The battery is on the same buss as the radios, so when the power goes out, the battery is already on line. Those power supplies have better voltage control, regulation and RFI filters.
FrensicPic
Los Angeles
A conventional battery charger (automotive type) would be pretty noisy I suspect.
I use an Astron power supply through a blocking diode with a deep cycle battery. The Astron output was re-adjusted to compensate for the voltage drop (.6 v or so) of the diode so 13.5 to 13.8 V (float V) is maintained on the battery terminals.
Essentially, the equipment is always on battery power with or without commercial AC.
prcguy
One of many problems connecting a battery directly to a power supply is when the AC power fails and the battery is run down you can kill a power supply trying to charge the battery back up with peak currents of 30A or more then long continuous current of 10-20A. It’s much better to separate the two using a 120VAC coil relay so it routes the power supply to the equipment during normal times then switches to battery when AC fails. Then use an actual battery charger on the battery.
jazzboypro
Laval
This is exactly what i'm doing and it works very well
jazzboypro
Laval
Are you doing battery direct to power supply or relay isolation?
Relay isolation. If i recall you helped me a great deal along with @mmckenna to put it all together. The link to the second post referenced by @a417 is the one i started when i wanted to have battery backup.
