12VDC Power Distribution Terminal Blocks, ETC?
iMONITOR
Silent Key
S.E. Michigan
I picked up an ASTRON RS-20M power supply. For starters I want to power four scanners and one CB. The power supply has two 20A posts on the back and two sets of Anderson Powerpols on the front. I want to run one short cable (2 conductor) from the power supply to the back of the radios then split it into 6-12 connections, one for each radio and some extras for future use. What are you guys using and recommend?
I've been looking at numerous options:
1610280996011.png 1610281064846.png 1610281160397.png1610281188746.png1610281272292.png 1610281544337.png1610281592697.png
Mr_Boh
The Land of Pleasant Living
Anderson PowerPoles are good just because they are good connectors and there are knock-offs that are compatible and just as suitable. It's pricier to get started with the tools needed to crimp them and the connectors themselves compared to blade or screw terminals, but good if you plan on being in this hobby for a while. I just like how easy it is to swap equipment and get power on the fly. You may find yourself making custom jumpers to go from PowerPole to various radio brands and other universal equipment.
The blade or screw terminals are better for more "long term" installs and cheaper to get going, so just know that if you go PowerPole, you are paying for the convenience of quick connect/disconnect.
I am NOT a fan of "banana" style connectors. I have never had consistency with the sizing on those. I have power supplies where the connector doesn't have enough friction so I end up just making short jumpers with ring terminals.
a417
If I was constantly changing equipment in a mobile environment, or a constantly evolving (like days or weeks between changes) setup I'd go with a powerpole based system - but that was if I was willing to commit to changing wire heads & all the like as @Mr_Boh stated.
If I wasn't doing that...I'd just use the bussman idea, like I'm currently doing now, as I have hundreds of spade connectors over various gauges, the fuses are all over the garage and I have complete portability between car, truck, workbench, mobile, etc...
I'm cheap. I'm using what I have, and what works. It doesn't need a big ol branded name on it.
iMONITOR
Silent Key
S.E. Michigan
I'm always adding, removing and changing things at my base. I want to make sure what ever I use doesn't have the possibility of shorting and causing a fire should something fall on them or if equipment gets pushed up against something metallic. Plus I have a curious cat that likes to sniff around! :cautious: When buying Anderson Powerpole stuff is there any prefered sources? Seems everyone is selling them.
a417
Ah.
I plan my power distribution to usually be hanging from the underside of a shelf or desk surface and the wires secured so that's not an issue. Also keeps it out of the nibbling range of the 7lb rabbit.
izzyj4
Ova here
For inside home shack, I use a Rig Runner connected to my power supply. My feeling is better protection running from a power supply to the RigRunner with each output power connector being fused. Plus the fact having Anderson PowerPole connections just make things easier for changeouts and quick disconnects if I have to work on a radio / scanner. I have a Blue Sea fuse block for my truck which I'll be installing for my radios / scanners / etc. for a more "permanent" mobile set up. This is what I feel is best for me.
KK6ZTE
California
BlueSea ATO fuse blocks. You can get them on Amazon in many configurations. I've used them in mobile installs for years with zero issues.
Cheaper, easier and more flexible than Anderson power-poles. Buy a box of spade lugs and you'll be set.
I second the BSS stuff. I have no qualms putting it into the emergency vehicles I build. Screw terminals mean you don't have to worry about spades pulling off in case someone goes digging into wires.
iMONITOR
Silent Key
S.E. Michigan
I was leaning toward Anderson Power Poles but things were started adding up quickly! A good quality crimping tool, a box of assorted connectors, and multi-connector distribution options were adding up to over $200. I went with the BlueSea solution. For my low current needs this will work just fine for an investment of about $30.
AK9R
Central Indiana
Did you include ring terminals for the wires and a crimping tool for the terminals?
prcguy
If you twist the bare wires with some pliers you don't need no wire nuts. Just put a little electrical tape on it when yur done. Or even a dab of masking tape will do.
Otherwise for amateur use I put Anderson Power Poles on everything because I have dozens of power sources and dozens of radios and they make life sooo much easier. Its really nice being able to take any radio or amplifier or charger or whatever and plug it into the car, house, go box, portable battery power, RV, whatever. And if all your friends use Power Poles then everyone is compatible.
However I would never use Anderson Power Poles in a professional environment like public service vehicles, etc, since a snagged power cable can become a single source of radio failure when lives depend on it. Especially when the user is not a ham or radio person tuned into quick troubleshooting when the radio goes dead.
You can get ok crimpers for Anderson Power Poles for $39 and a bag of 25 pairs of red/black 30A Power Poles with roll pins is about $25. I use a lot of Power Pole distribution blocks with 3 to 8 outputs and also have a big MFJ thing with a volt meter and various fused Power Pole outputs that cost more than its worth but I've used it a lot over the last 20yrs.
Red wire nuts.
