Chris516
I can't find this frequency in the region. It is not programmed into my scanner, yet it keeps stopping on it.
I hear RFnoise similar to when listening to a car radio, while driving through a big bunch of trees, and the car radio signal is repeatedly interrupted.When it stops on it what do you hear?
I am not tearing my hair out about it. Just that the scan repeatedly stopping on that frequency is annoying. Even after I try lock it out.It's not an allocated channel. It is between 132.000 and 132.125. I wouldn't worry about it.
If you have the step set correct, it shouldnt stop at all. 25khz spacing.I am not tearing my hair out about it. Just that the scan repeatedly stopping on that frequency is annoying. Even after I try lock it out.
It is the BC75XLT from Uniden. Next time it happens, I will do double L/O. I had just doing it once,What scanner do you have? If it's a Uniden you should be able to lock it out permanently by double push the avoid L/O button.
Remember that you'll reset that lock out with the next scanner write if you haven't added the frequency to the lock out table in sentinel.
Most other scanners work the same way.
/Ubbe
