vu3dxr
DIY – 137 Mhz V-dipole antenna for weather satellites reception
A V-dipole for NOAA weather satellites on 137 MHz has been published by 9A4QV and it seems to get very good results. The designed antenna works at frequency 137 Mhz with omnidirectional radiation pattern.
The length of the each leg should include the connecting wire’s length up to the coaxial connector or coax. For my case connecting wire’s length is around 6 cm for convenience. Here in my case, PVC end cap acted as antenna elements mount, which is structurally stable than electrical terminal block.
DIY – 137 Mhz V-dipole antenna for weather satellites reception – DXR Technical Bits (vu3dxr.in)
