153.245 - renir
mmisk
Ottawa Canada
The activity on 153.245 seems to be a VC for unknown sites:
Perhaps Site 31? Will keep on watching.
Site 31 Unknown
141.600cc 2-112
153.095
49- Outaouais (Mt-Ripon)
76- Outaouais (Mt-Ste-Marie)
78- Outaouais (Edelweiss)
86- 140.625 Unknown
89- 162.165cc Unknown
mmisk
Ottawa Canada
Looks like this is the system it belongs to.
EDIT: Looks like a Ripon site
Site 2.86
140.595vc 2-0919
140.625cc 2-0925
141.105vc 2-1021
152.645vc 2-3329
153.245vc 2-3449
162.105vc 3-1126
IdleMonitor
The Ottawa Valley - Eastern Ontario
Where is this info from that you got? The RR database shows the following info for the Ripon site.
2 (2) 049 (31) Mt-Ripon Outaouais
141.990a
163.785c
164.190a
172.050a
Your 140.595, 140.625, 141.105 are all listed for 078 (4E) Edelweiss Outaouais
Your other frequencies are associated with sites that are nowhere near my listening area.
So I'm starting to get confused. Which site should I be adding this frequency to?
Site 2.86
140.595vc 2-0919
140.625cc 2-0925
141.105vc 2-1021
152.645vc 2-3329
153.245vc 2-3449
162.105vc 3-1126
mmisk
Ottawa Canada
If you monitor the control channel with Unitrunker, it will give you the frequencies and other relevant information.
It says Ripon, but there could be more then one site at Ripon, but I don't know this for sure.
Frequencies are shared throughout the whole system.
Mike
mmisk
Ottawa Canada
I assume because no one can listen to Renir, that the database is not updated.
For example this is the correction for: 002-078 Outaouais (Edelweiss)
This is from the data stream on 140.595
140.595c
140.625
140.700
140.805
141.165
164.280
165.495
IdleMonitor
So is 141.105a no longer associated with the site then?
Perhaps an update to the database of your findings would help.
I'm just trying to figure out where my frequency findings all fit into place. That's all.
140.595c
140.625
140.700
140.805
141.165
164.280
165.495
IdleMonitor
What's weird about this one is I can only hear any sort of ENC activity off of 164.280 and 165.495, but I can't hear or so it seems any other frequencies associated with this site. I don't hear the control channel, likely cause it's still too far away for a decent signal.
140.595c
140.625
140.700
140.805
141.165
164.280
165.495
DaveH
Ottawa, Ont.
The DB shows 140.595 and 140.625 as belonging to the same site, but apparently both being CC's have split off into separate sites. Some VCs have no doubt shifted, and new ones appeared; all over the VHF band (e.g. 152.525, 152.645, 152.690, 152.810, 153.245 just in the 152/153 range).
Another (weak here) CC is on 152.465, nothing in the DB which matches. Also 141.600 is noted earlier.
I use Pro96Comm which also populates VCs auto-magically, given enough time. Some sites are unbusy even during the day.
You can work backwards getting NAC from the VC, and matching NAC from site CC but it is not always unique.
Dave
mmisk
Ottawa Canada
152.465 is not bad tonight.
Site 2.122
141.885
152.465cc
152.525
164.040
