153.830 hearing aircraft in central IL
In my feed scanner I have 153.830 I know it is MABAS Red Fireground, but my question is I hear aircraft all the time on it I think I have heard United something, The scanner does AM aircraft also.
You can listen to my feed and hear it sounds a little muffled but heard quite clear.
My question is, has anyone heard this also and what freq are they actually using.
I am located in Central IL, in Ladd.
aaknitt
Not sure if you're having the same issue, but I have a PRO-2044 that is absolutely horrible about letting aircraft band comms splatter all over other bands. If your scanner is like mine, the actual transmission is probably nowhere near 153.830, but is actually in the AM aircraft band. The muffled sound you describe sounds very similar to what I experience.
Andy
gewecke
Banned
Illinois
I live in bloomington and monitor all the MABAS channels as well and have never heard a/c on mabas red. Could it be that you heard an image from the aircraft band,or maybe intermod from a chopper from OSF? Medflight flies over ladd on occasion and they dispatch on 159.5100mhz.FM /88.5pl.
n9zas
Probably a problem with scanner the bleeds through on my scanner of that certain aircraft am freq. maybe cheaply manufactured scanner by uniden for RS.
N9JIG
Sheriff
Moderator
Far NW Valley
This is pretty common, especially with older scanners. It is an image from the aircraft band. Try to see if you hear the same aircraft traffic on 132.425 or 132.225. If so then it is an image from there.
Some scanners pick up images on a frequency 21.4 or 21.6 MHz. above the actual freqs, the formula is Freq + (2xIF), the IF is usually either 10.7 or 10.8 MHz. Double the IF (resulting is 21.4 or 21.8) and subtract that from where you are hearing the image and you should get the actual freq. Don't worry if it is off by a little bit.
usswood
Terre Haute, IN
I would get this all the time on 155.610 which was an old police Freq on certain old scanners...seemed only to happen to if the aircraft was directly overhead as I am in a departure corridor for Indianapolis Westbound traffic. Central Ill, you probably are also for West and East bound not to mention Northbound going into O'hare, next time go outside and look up and see if you can see that guy
Thanks for that info Rich might have to do some playing around with my scanner when I am bored.
Quote:
Yes next time I am listening and hear it will go out and see if any planes are around, and will try to find the actual freq. they are using.
