TinEar said:I think you mean 153.845. Don't know the reason but am glad they do since I can't hear the 46 mHz freq from my location but hear 153.845 very well. They don't transmit a PL tone with it though which I wish they would since it would get rid of the occasional bursts of noise which make the scanner stop on it.
TinEar said:Well, Mike, all I can argue is the point that there is no PL tone for that freq that MY scanner will pick up. I've checked it countless times and the screwy, slow scan of the 785 goes through all the tones and just continues to click them off and never stops on one. I'd like to have a PL tone set for every freq in my scanner for all the obvious reasons but there are a handful that just show CSQ traits - and the 153.845 freq is one of them. Just as a test I'll throw that 151.4 tone in and see what happens. As much as I hate that function on the Uniden 785D, I've successfully found and confirmed tones for hundreds of freqs with it so at least I know it works.
[By the way, while I'm typing this, there is testing going on on 165.2375 which I have listed for Customs in DC. But this is so loud it must be at BWI. Check it out if you get a chance.]
jimv said:Gentlemen,
I live in Frederick and can confirm that there is no PL associated with 153.845 MHz. When the Department of Fire Rescue switched over to the county's TRS, all the active volunteer firefighters were supplied the high band pager. As far as I understood, Frederick did not want to support the low band system anymore, thus, they incorporated paging with a new high band/ TRS simulcast system. Although 46.34 is still up and running and is also simulcasting the TRS Main TG, if this transmitter takes a poop, I do not think it will be repaired.
TinEar said:[By the way, while I'm typing this, there is testing going on on 165.2375 which I have listed for Customs in DC. But this is so loud it must be at BWI. Check it out if you get a chance.]
