155Mhz Folded Dipole
Ghost4658
Mayflower Ar.
Does anyone know anything about this ant.
It is a 155.655Mhz repeater ant it has 4 folded dipole ant's on a 20ft alum pole. When thay put up a new one I got the old one.
I don't have a pic of it.
rcvmo
Romulus, Mi.
One thing for sure...........
One heck of a scanner antenna for VHF freq's. If your interested in just that frequency, your scanner would certainly be working at optimum performance on 155.655 MHz.
Otherwise, an excellent antenna all the way from 140 through 170 MHz and then some.
If you wanted to retune for transmit on a hamband if you have the proper license, then you might want to consider taking up aluminum welding.
I have one at work on the 400 MHz band. Does beyond my specs for an antenna.
Stick that thing up and get it connected. We want to hear your results!!
rcvmo
