Hi TinEar
159.15 is indeed the VHF simulcast of Citywide 1. As previously and correctly posted, you will find 1D and Citywide patched together during "low traffic" times to save on dispatchers. This goes way way way back into the old conventional days when all the districts would patch together on midnights... CW/1D, 2D/3D, 4D/5D, 6D/7D.
I think the reason you can't tell is because of the way the scanners seem to handle patches (or at least DC's patches, but I've heard likewise about other areas also). I notice that when a patch is enabled, the scanner will only receive the channel that originated the patch, the channel that is patched in will not be detected. When DC simulcasts priority lookouts, sometimes they are done on a single simulcast talkgroup, and other times, the other districts are patched to the dispatcher broadcasting the lookout. When the simulcasts are made through the patching method, I only hear them when the scanner stops on the district that created the patch. I've confirmed this by watching the patch on Trunker.
Dewey
