167.53750 FBI Ch. D5 National Emergency
Priority-One
Anonymous participant
Banned
Bronx, NY
Can anyone elaborate on the use of this channel? is it P25 or analog?
Does every FBI office use this frequency nationwide and is it repeated?
167.53750
nd5y
Wichita Falls, TX
Back in the analog days it was supposedly for Special Operations Groups, at least in the DFW area.
It was supposed to be a repeater with an input of 163.8625.
I have never confirmed any activity on it in north TX but that doesn't mean it isn't used.
It is shown in the database for Houston. I don't know about your area.
Priority-One
Banned
Bronx, NY
I saw it in the DB for San Antonio. I am currently in NYC and gonna see if I get any hits on it
ChrisP
Portland, OR
167.53750
From what I have seen, yes, it is in every FBI radio. It can be repeater or simplex. And it is programmed as both P25 and analog.
I have actually heard some units using it in analog, simplex in some areas still.
It was in use in P25 mode at the Super Bowl in Houston...
- Chris
ecps92
Taxachusetts
and to Elaborate, it has also been seen programmed
a. Simplex for both the input and output
b. Reversed Pairing
c. Don't get hooked on $167 also seen as $#67 in some Regions.
As Chris said, it's been seen Analog, but with P25 that seems to have gone away
Not having the D Zone Pre-programmed is like not having the NIFOG channels pre-programmed to listen to..., You never know when, where or for what...
- Chris
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Ditto with not having the AGA (All Government Agencies) 'itinerant' frequencies programmed. In my area (Central Virginia), the Blue Ridge Parkway maintenance crowd use two of them for miscellaneous operations. Narrowband FM...nothing exciting.
But the other day, had a few USGov users pass through using 163.100, in P-25, with several of the units encrypted.
You never know what you might pick-up. :wink:
ecps92
Taxachusetts
what NAC did you get, as I have seen each agency use it's own :confused:
ecps92
Taxachusetts
Interesting. Thanks
We've seen info on this freq with $293 but no Agency to ID, other than
thoughts it could be a Travel Channel for Fires/Disaster Responses
Next thought would be to compare RID vs known VHF Agencies
$293
Talkgroup 1
AES encryption
kb4cvn
Silent Key
What I find even more interesting is the more than common use of Logical ID (LID) 1 for all the radios in a conversation, both secure and unencrypted digital.
I hear car-to-car intercom type traffic on a fairly routine basis out on the highways (& interstate) when I travel. Male and Female users chatting about driving, lane changes, pit stops, etc., and all of the user radios are using the same LID number! (Almost universally with NAC $293 on Talkgroup 1.)
I can only assume that some Tech squirted the programming into the radio(s) and handed them out, not caring about specific user ID's.
Hooligan
Clark County, Nevada
Abiding by P-25 Radio ID conventions can present an operational security issue.
I have seen many federal entities do this and found it odd.
