172.1000 Trunked System
ScannerSK
Weld County, Colorado
I am just checking to see if anyone has information regarding a trunked system on 172.1000? This is the control tower channel and is rather weak at my location south of Greeley.
ecps92
Taxachusetts
Are you able to get a SysID??
I can tell you, in my travels [varies by scanner] that in the 172-174 band I have caught images from a 900 Mhz TRS.
edftc
colorado
In the Ft Collins area - that frequency range covers data (telemetry) from low power transmitters - with water and temp readings. Usually near low lying flood zones and bridges.
ScannerSK
172.0875 Contol Channel Now
The control channel has moved to 172.0875 this evening! The control channel sounds different (more like a MotoTurbo system than a standard P25) however the PSR-500 is displaying a P25 system ID of AD5 or NAD5.
Sound familiar?
ScannerSK
Tower Information!
System ID : AD5
System Name :
WACN : BEE07
Tower Number (Decimal): 202
Tower Number (Hex) : T0202
Tower Description : (null)
Control Capabilities : Voice,Registration
Call Sign(s) :
Timestamp : Sun Nov 29 20:04:21 2009
-Tables
#Format: Table ID,Base Freq,Spacing,Input Offset,Assumed/Confirmed,BandWidth
00,162.00000,0.01250,-6.97500,"Confirmed",0.01250
01,162.00000,0.01250,-8.77500,"Confirmed",0.01250
02,162.00000,0.01250,-1.06250,"Confirmed",0.01250
03,162.00000,0.01250,-8.80000,"Confirmed",0.01250
04,162.00000,0.01250,-4.60000,"Confirmed",0.01250
05,162.00000,0.01250,-5.68750,"Confirmed",0.01250
-Frequencies
#Format: Channel,Usage,Frequency,Input Frequency,Hit Count
"01-0807","c",172.08750,163.31250,0
-Neighbors
#Format: TowerID,TowerIDHex,System ID,Channel,Frequency,Tower Name
203,"T0203",ad5,"03-0808",172.10000,""
ScannerSK
172.10000 Tower Information
FileVersion:5
-TowerInfo
#This section is here for information only. With the exception
#of the Call Sign(s), This data is not Read back into the program at all.
System ID : AD5
System Name :
WACN : BEE07
Tower Number (Decimal): 203
Tower Number (Hex) : T0203
Call Sign(s) :
Timestamp : Mon Nov 30 06:19:22 2009
-Tables
-Frequencies
"03-0808","c",172.10000,163.30000,0
-Neighbors
202,"T0202",ad5,"01-0807",172.08750,""
ecps92
Taxachusetts
Looks like it Could be IWN
U.S. Dept. of Justice: Integrated Wireless Network (IWN) - The RadioReference Wiki
FileVersion:5
-TowerInfo
System ID : AD5
System Name :
WACN : BEE07
Call Sign(s) :
-Tables
-Frequencies
-Neighbors
ChrisP
Portland, OR
Not IWN, but NOAA. (IWN is System ID 715 everywhere it's on the air so far)
A while back I found this Request For Information on combiners and multi-couplers for a VHF trunked system to be built in the Boulder area:
https://www.fbo.gov/index?s=opportu...83329c46dcbaf&tab=core&_cview=0&cck=1&au=&ck=
This was posted back in 2008, but I guess the system finally made it on the air. The same frequencies you are hearing are listed on this page.
- Chris
greenthumb
Colorado DB Administrator
Looks like NTIA, and I think they're on the NOAA campus on Broadway in Boulder. Anyone over that way hearing anything on 172.0875, 172.1, 170.6, 169.05, 168.6875 or 166.8125?
scanlist
Scanning since the 70's to today.
Greeley, CO
No signals on any of those at the daytime job in Boulder.
Same situation up here in Greeley I get nothing. If the site(s) are in the Metro area they are not on any mountain area towers.
Audiodave1
Chadds Ford, PA
I have it weak on 172.0875 from Loveland. No decode on UT.
I also have a CC on 139.0625 that had one group active yesterday. I'll post the ID later when I pull it out of the UT file. It's a big signal on an attic mounted VHF GP antenna.
Dave
greenthumb
Can you run pro96com on the control channel if you have the capability, Dave?
Audiodave1
Chadds Ford, PA
Not enough signal to get a clean decode on trunker on the 172 channel. Only 1 bar of 5 on the 785 (discrim is on a 2005)
Dave
