173.215
C
comsec1
Guest
does anyone have any idea what this freq is used for. dead carrier with two beeps every 5 seconds or so.
very strong near my house in northern nj
thanks
INDY72
Indianapolis, IN
LoJack AVL.... if you see some police cruisers with four Hi band ants on the roof cruising around.. They would be homing on the tones. LoJack is the least expensive, and oldest of the AVL systems. Also available is one based on GPS, and the Teletouch/Teletrack 900 MHz AVL systems. Teletrack is supposed to have one so small you can put it on a person's belt buckle and track em almost anywhere.
JamesO
McLean, VA
From my understanding the most common LoJack frequency is 173.025 MHz, however, it is possible they use 173.215 as well??
JamesO
nd5y
Wichita Falls, TX
LoJack is on 173.075 and doesn't have a dead carrier.
The 173.2 - 173.4 range is mainly used for telemetry and SCADA.
That is what you are probably hearing.
Tom
PJH
In addition, Lojack uses a 1200bps data burst and not a tone setup. It esstentially sounds like MDC1200.
Joseph11
You're right, it sounds like MDC-1200. I once did a search and found a frequency with constant MDC-1200, now I can identify it as LoJack.
