173.375
Marcy57
I have been monitoring this freq. awhile anybody have any ID on the user?
it,s a mix of encrypted and in the clear , the voice transmissions are of course
weaker but def. in clear not sure the two are the same user? or seperate.
tks in advance...73,s Marcy
ecps92
Taxachusetts
IF you can get the NAC or NACs, that will help narrow it down
58006
NY DB Admin
Inside The Blue Line
Where are you hearing it?
Marcy57
the NAC would not come out, hearing it in LI,NY...Marcy
murphcc1
Are you near JFK?
Possible TSA freq!
ecps92
Taxachusetts
Since TSA used prior FAA VHF [the 173.3750 is not one of those] but is now moving to UHF - likely Not.
and 173.3750 is not even a NTIA assignment, that is FCC.
173.3750 used to be one of the old Press Relay channels of days ole (IY)
Are you near JFK?
Possible TSA freq!
k2hz
Rochester, NY
173.375 is FCC Part 90, not federal, and I see several analog and one DMR license in the LI/CT area but no P25. Is this really P25??
58006
NY DB Admin
Potential
WPMP466 Huntington Coach, Huntington Station/Farmington NY Suffolk County
Emission Designators
11K2F3E-2.5 kHz deviation FM "narrowband 12.5 kHz" analog voice
20K0F3E-5 kHz deviation FM "wideband 25 kHz" analog voice
4K00F7W- 6.25 kHz voice and data NXDN (IDAS, NEXEDGE)
7K60FXE-2-slot DMR (Motorola MOTOTRBO) TDMA voice
innokuous1
Long Island, NY
From north shore in Brookhaven Township I'm hearing school buses. Strong signal from base station calling itself "Northport." It's an analog simplex operation. Sometimes I hear the bus(s), sometimes I don't.
k2hz
Rochester, NY
If what you are hearing is Huntington Coach, then 173.375 is the repeater input. Check the 160.170 repeater output. Huntington does have a dispatch facility in E Northport.
tvengr
Well Known Member
Baltimore County, MD
Frequencies in that range were also used for filming motion pictures. I monitored several MGM films being shot in my area. They were also used for newspaper distribution.
