"Cutting an antenna."
That typically means 'fine tuning' an antenna, making small adjustments in length. You start with an antenna who'z length is longer than needed but in the 'ball-park'. Then you make adjustments in that length to get it more 'right'. The biggy with that is that if you go too far, it's awful hard to put back, you know? The closer you get to 'right' the smaller the 'bites' you cut off of the thing. Make sense?
- 'Doc
(The 'catch' to tuning an antenna is that if you change that antenna's environment, mounting location, etc, you probably will need to re-tune it. That means that in some cases it may be too short, and that isn't very easy to get around sometimes. Not something you have to spend a -lot- of worry over, but keep it in mind.)
