Alrighty - right now I have a pretty basic and low budget setup for my 1998 Pontiac Firebird. I use a Bearcat B350C with a Radioshack on-glass antenna.
Now, I want to re-do this setup, as I am not satisfied with it, and I'd like your help and suggestions with this process.
The first thing I want to do is replace the on-glass antenna with a permanent one on the car. Magnet mounts are not a solution for me as the only location they stay on is my hood, and that's no good.
The antenna I was considering most is the PCTEL MONR33 - I believe in previous posts everyone who used it was satisfied. Additionally, I really don't mind a four-foot antenna on my car if it means fantastic reception compared to what I use now.
Link: http://www.tessco.com/products/displayProductInfo.do?sku=20272&eventPage=1
I will include pictures of my current set up and rear of the car to show you where I believe I should install the antenna. Additionally, if you can recommend an alternative antenna, I would be much obliged.
One of my questions is if this antenna will function well if the rear hatch of my car is not metal; honestly, I'm not entirely certain what in the heck it is.
I should also mention the primary frequencies I monitor are approx 42 Mhz, 154 Mhz, and 156 Mhz. Secondaries (not often) are in the 400's and 800's.
