I have a 1999 chevy conversion van ,with a fiberglass "hi top". I have an nmo "drill through" mount ,on the lip of the back door and an Austin Spectra antenna.. I am experiencing some static and scratching noises but only from distant stations. 20 or 30 miles away. When the vehicle stops , motor still running , the noises go away. I have driven on an empty road , had the noises , then completely turned off the engine and coasted. Noises did not go away. When the vehicle rolled to a stop noises went away. If the van is parked and not turned on ,reception is excellent. Is it possible that i have the antenna located in a bad spot? I don't think i can mount it on top of fiberglass roof, any suggestions will be very helpful. Thank you..
