1st time programming
1dozer
This is the first time I have programmed my BCD996T myself, I'm getting things figured out o/k but for one frequency for EMS which is 149.4400 for page out. My problem is that it works to good, is there a way to get only the page 1 or 2 areas not everthing within 30 mile range.
captclint
Mountaintop, PA
This is the first time I have programmed my BCD996T myself, I'm getting things figured out o/k but for one frequency for EMS which is 149.4400 for page out. My problem is that it works to good, is there a way to get only the page 1 or 2 areas not everything within 30 mile range.
Probably not unless they use tones as well as voice. If they use tones, you can select ones you want to hear, (you will have to find these tones by asking, or by using some software) but you will be locked on just listening to that one page freq. You will not be able to scan. Fire Tone Out - The RadioReference Wiki Might help if we knew your state and county to see if there are any other options.
DaveIN
Founders Curmudgen
West Michigan
I you only wanted to hear the EMS agency of interest, then you you use the Fire Tone Out feature, or if multiple users have a different CTCSS or DCS you could use that. I also like the attenuator idea.
1dozer
Thanks for the input I'll try the different ideals. Any other thoughts I'll try them also.
KE4ZNR
Radio Geek
The gentlemen above gave you the options available...up to you to decide which of the above is the best option for your specific situation :)
Happy Monitoring!
Marshall KE4ZNR
1dozer
I pretty sure I said I would try there ideals but if there was any other thoughts I'd try them also. Thanks for everyones input.
