2 BCD536HPs side by side-P25 issue on 1
Hillside1
I have 2 536HP's side by side using the same antenna. I'm in NJ monitoring the NJICS
p25 Phase 2 system on the West Orange simulcast. One radio hears them clearly while the
other radio displays the talkgroup but no audio comes out. I put in a few analog frequencies
and the radio does have normal audio, so it's not a speaker/audio issue. This radio was
previously working fine. Any suggestions before I ship it back to Uniden?
letarotor
Arlington, TX
What kind of splitter or multicoupler are you using? If it's just one of those cheap BNC splitters you are experiencing signal loss I'm sure. I don't know for sure if that is what may be going on with the radio but it's a likely candidate. If you're using a multicoupler that is a good one you shouldn't experience any signal loss.
It could also be that the sensitivity of one of the radios is better than the other. Unfortunately, that happens with all production line items when it comes to radios. It's not always a drastic difference but unfortunately identical radios don't always have the same sensitivity or selectivity.
I'm trying to move some radios up to my living room area from my radio room. I spent $200, $185 plus shipping, to get a new Stridsberg 4-port multicoupler. That gives me the ability to run one antenna to it, have it amplified by 6db, and then run it to four different radios. They make them in 2-port versions also which are cheaper priced. They are a superb company with a superb product and this is the third multicoupler I've bought from them sense 2002. It's not because any of them have gone bad, it's just because I needed more. And they have a lifetime warranty if something goes wrong with them. But they work wonderfully and allow you to hook up multiple radios 21 antenna without any signal loss.
One thing you might try is using the antenna feed coming in and just run it to one radio at a time. I know that makes it impossible to do the side by side comparison. But if you have a busy channel with a lot of traffic you can pretty easily compare each scanner hooked up to the same antenna I just quickly changing which radio you put it on. Of course you're comparing them separately but it'll give you a good idea if whatever you're using as the splitter is causing signal loss to one of the radios.
Brian (COMMSCAN)
Sent from my SAMSUNG-SM-G930A using Tapatalk
Hillside1
Not the splitter. I removed the splitter and used the same lead as the radio that works. Same situation. I can see the radio stop on the various talkgroups but no sound.
letarotor
Arlington, TX
One other thing you might double check is if your squelch is set too high on the radio not getting the signal or at least passing audio. I know I had an issue similar to this not long ago and I had accidentally turned the squelch up. It was stopping on a channel but then I wouldn't get the audio most of the time. And it could be that you are having a problem with the radio itself of course. I know I'm going through something right now with my SDS100 that has worked perfectly since I got it after pre-ordering it. But in the last month, I'm having severe issues with receiving signals now. I'm not sure if it's the scanner or if it might be the site in my situation? But over the last month I can't hardly hear most of the transmissions in my area. I'm trying to determine if I need to send mine back for a repair or not? Good luck and I hope it is something that is fixable so you don't have to send it back. I guess you've also made sure that the attenuator or the global attenuator is not on? But it sounds like if it's stopping on the channel and you're just not getting the audio, and I guess your signal strength meter shows a receivable signal, then it may very well be a problem that the shop will have to look at.
Here's an example of what I'm dealing with now and it probably will look fairly similar so what you are doing. But it is a different problem in my case I think? :)
This is a friend's radio that is working fine and mine, of course, having the issue.
https://photos.app.goo.gl/gE4nxiNxe1cxcXim9
Brian (COMMSCAN)
werinshades
Chicago , IL
Is it possible that they have encrypted some of the talk groups? That's how the scanner handles encrypted talk groups.
Hillside1
No encryption. Just one 536HP, stopping on talkgroups but no sound. The other 536HP working normally at the same time using same antenna.
Ubbe
Stockholm, Sweden
You can turn down the squelch to 0 and try, it should still work but will not cut off the signal if it's weak in digital mode.
Run Unidens RH-536HP program or the Android Siren app and see if both scanners really goes to the same voice channel. Do IFX on that muted channel, Func+7.
/Ubbe
