KC9LQV
Does anyone make a 2 hole, diamond shaped BNC mount that would be suitable for replacing the UHF connector on the back of an Icom 2720H? I'm sure not having any luck finding one.
You probably won't find one to fit that shape and size. The BNC is quite a bit smaller diameter than the UHF. I can't even find an N connector with that type of chassis mount, and that's roughly the same diameter as the UHF.
Your best bet would probably be to remove the UHF connector from the radio, bring it to a metal shop and have them fabricate you a blank using the old one as a template. Same size and shape and same mounting holes, then have them drill a nice hole in the center, and buy yourself a good bulkhead mount female connector. I would personally go with an N over a BNC, but either one would be better than the UHF, that's for sure.
RF Industries RFN-1022-1 N Female Bulkhead | TESSCO
Amphenol RF 31-2221 BNC Female Bulkhead | TESSCO
