A while back, I purchased a copper tubing J-pole antenna off of eBay (2 Meter VHF J Pole Base Antenna Heavy Duty Amateur Ham Radio Scanner 144 148MHz | eBay) to use with my 2 meter rig.
Well, just recently I purchased a dual band rig, the Yaesu FT-7900R. Great radio, but I've only been using it on 2 meters so far. Don't have an antenna tuned for 70cm. However, I decided to do a little investigating, and saw on the above referenced link that although the antenna is pre-tuned for 144 - 148, it also says it can be used on 70cm.
My question is...how effective would this antenna be when operating on 70cm? I'm thinking about buying a dual band mobile antenna and mounting it up in my attic, but would rather not if the j-pole would be somewhat effective on 70cm and not do any kind of damage to the radio itself.
Thanks in advance for any information provided.
