@billdean - Another thing that might get an operator into using 2 meters, or get more out of it, is the ARRL VHF contest that happens three times a year. The contacts are all simplex, no repeaters are used. One can use FM and or SSB as well as digital (typically FT8). The point of the contest is to use/experiment with the radio gear you have.
Another way to use VHF, many amateur operators overlook, is making contacts via satellites in space. The first contact I made as an amateur radio operator was through SO-50 using an inexpensive Baofeng handheld. One can spend quite a bit on gear to make contacts via satellite, but it is not mandatory. The most popular satellite operators use is the International Space Station (ISS). Occasionally, the ISS will TX a series of SSTV images using 2 meters. While that is a RX only exercise for anyone, it allows a person to use their gear to receive the signal, record it and then decode to get the image. There are apps one can use on a phone to decode the signal “live“ as well by placing it near the radio.
While I started with an inexpensive Baofeng, I have spent much more since then to improve my TX/RX capabilities. Still, one can have fun for very low cost with this hobby. In time, operators learn that the antenna is the more important part of their gear.
