2 NX-5800s as a repeater
911jeremy
Charleston, wv
I'm needing to connect 2 NX-5800 radio to repeat each other, one DMR the other P25 Trunking. The only thing I can find in the Kenwood manual is for Mobile Relay, but that's only when they are in multi deck situations, which these will not be. I am aware of the timing issues that this will cause, but I'm trying to test a theory. Can anyone help, cause Kenwood tech support didn't have a clue.
You can use the pins on the rear DB25 connector to do this, although you need to be really careful.
Pin 6 - Mic 2 input
Pin 25 - Mic Earth (ground)
Pin 11 - Ground
Pin 17 - AFO
or
Pin 19 - Detector output
You'll need to program auxiliary I/O pins for PTT and a COS
You'll need to do some work to do the audio interface, as the levels will not be a direct 1 to 1 interface.
Kenwood tech support isn't going to spend a lot of time working with you on an experiment when they sell a product that does the same thing, so don't blame those guys for not helping.
kd4efm
Florida
The cross cable is mode dependent, there is a aftermarket option that will do much better, and not channel mode dependent.
HOWEVER, the codecs might get you a ****ty result, but for short term use, it is doable.
I do not have the schematic, but I do know the guy who makes them, and is on my facebook NX5000 Users group.
