Hi all -
I'd like to get some opinions for 2 different antenna location setups I am considering:
The antenna would be something like this: CSB-750A COMET 146/446 MHz Dual-Band High Performance Mobile Antenna, Chrome, Gain: 3.6 / 6.1 dBi, Connector: PL-259 (UHF), Max Power: 150 Watts, Length: 42"
The radio would be a 2m / 70cm dual band, either a mobile or portable with 50 - 100 watts power being used as a base station from my basement.
For the antenna, I would like to know which of the following location will give me better results:
1. antenna mounted on the floor of my attic (about 10 feet above the ground). Would be almost directly above my rig using maybe 15 feet of coax (maybe 20 feet max, but probably closer to 12 - 15 feet.)
or
2. same antenna mounted outside on my antenna mast at the other end of my house, about 20 feet above the ground. The bottom of the ham antenna would be about 6 feet above the edge of my roof. This antenna would be sharing the mast with my sc-2 scantenna, and would be positioned at the same place vertically as the scantenna. There would be maybe 2 -3 feet between the 2 antennas. This would require about 90 -100 feet of coax. I can use RG8 coax for this, if necessary.
Is there a clear best way to go here?
I am in a suburban neighborhood in central Pennsylvania with lots of houses and 50 foot trees. The terrain is hilly, with mountains maybe 4 miles to the south and 15 miles to the north. I have no trouble hitting a 2m repeater and a 70cm repeater, both about 4 miles to the south, possibly located on the mountain using an HT on low power and a rubber duck from my basement, but I'd like to improve my range a little.
*** What I am trying to get a sense of here is the performance trade-off between short coax, indoors and lower mounting position vs longer coax, outdoors and a slightly higher mounting postion using the same antenna. If the outdoor option is significantly better, I'm sure a different type of antenna would improve the performance even more, and I would actually use whatever type gives the best results.
Thanks!
or
Thanks!
