WS1095: 2 scanners, 1 computer
PrivatelyJeff
Has more money than sense
Kings County, CA
I have 2 1095s in my car and I was wondering if I could plug them both into my laptop at the same time to do updates and what not. I know the SD cards are just seen as mass storage devices but what about the units themselves. I don’t want to try some firmware update and wreck them.
NOTES: The will be connected to a USB hub with short cables from the units to the hub and a long cable from the hub to the laptop and pulling the cards is NOT an option.
Ubbe
Stockholm, Sweden
It has been noted elsewhere that they tend to use a common usb driver so that only one scanner at the time gets a connection. If you manage to solve that computer problem the scanners SD cards will be given different drive letters and are safe to program as you select in the EZScan software which signle drive to use.
/Ubbe
PrivatelyJeff
Kings County, CA
/Ubbe
Hummmmm. Maybe I should email whistler support. Thanks.
Wackyracer
Make 2 different vscanner folders, active the desired one on each scanner. that is one way to do it with a single pc and 2 scanners.
