Sentinel: 2 Scanners, 1 Sentinel
Aremel
Cheyenne
Can I use 2 scanners with the Sentinel software? Not simultaneously of course, but can I use Sentinel for programming say a HomePatrol-II and an SDS-100? Perhaps put together two different profiles containing different sets of favorite groupings? Thx!
drdispatch
What's the frequency, Kenneth?
Fightin' River, Michigan
+1 on what Whiskey3 said. To expand on that, I've got a 436HP & an SDS-100 and use Sentinel for both without issue. That being said, if you do this, pay close attention to the "Target Model" at the bottom left of the window before you read to or write from the scanner.
mc48
Monroe County, NY
You can transfer favorite lists between the two versions of Sentinel by using the Import/Export function under File.
The best way is to enter the data is into the x36 version and transfer to the HP version, this way you can program Q-Keys and NAC if you desire.
