PSR500/PSR600: 2 Scanners Connected to 1 Computer
TexScan780D
I am looking for the GRE instructions on how to connect the PSR500 & PSR600 to the same computer?
gmclam
Fair Oaks, CA
Depends on what you want to do. Do you want the audio from each scanner connected? Do you want to control each scanner? Or something else? All of the above? It takes two sound cards, two programming cables, two instances of respective software loaded to do the work.
lehigh4me
Lehigh, Iowa
It works with Win500, I have a 500 and 600 and have had both running on separate instances of Win500 at the same time.
lehigh4me
Lehigh, Iowa
Only need one installation of Win500, as it will start a second instance of Win500 from the same Win500 program. You do need two cables and two sound cards. I am using the sound card in the computer and a Sabrent USB sound card. Works great for me. By the way I also have a TRX-200 and a Uniden 996XT and Pro2096 on the same computer. But I don't record the audio on the Pro2096.
