2 zone scan at the same time
Whospoonbill
I was wondering can you scan 2 zones on a apx at the same time if that makes sense
GTR8000
NY/NJ Database Guy
BEE00
If you're asking if you can scan channels that are in different zones in one scan list...yes.
If you're asking if the radio can scan two separate scan lists simultaneously...no.
The radio has a single receiver, and therefore can only receive one signal at a time, regardless of what "zone" it's programmed in. One scan list at a time.
Whospoonbill
So like if I had the zone selector on position (a) switch on the top of the radio and I had b and c programmed a for fire b for ems and c for pd can I have it scan ems and fire at the same time if that makes sense or will it only scan if it on that position
GTR8000
NY/NJ Database Guy
BEE00
It will scan whatever scan list is assigned to the personality of the current channel.
clbsquared
Isle of Wight County
It will only scan from one scanlist at a time. You can have channels from multiple zones in a scanlist but you can’t scan from multiple scan lists. You may have to create a new personality, a new zone and a new scanlist to accomplish this if you’re trying to have a multiple scanlisls with the same channels in it.
nhfdcadet
CETsr
New Hartford, Ct
when you build your scan list you select zone/channel for each member of the scan list. You can put whatever you want in there.
Whospoonbill
So I can program it to scan Police and Fire even know I’m in zone 1
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
As was already posted, you can put whatever you want in your scan lists.
I'm going to be "that guy". If this is trunking I'm going to assume you are not an authorized user on the system. If so you probably need to stop as it's obvious you don't know what you're doing and you can cause issues with users on the system (missed/wrong audio and delayed access when trying to talk).
I'm not trying to be the radio police, I just don't want you endangering the life of a first responder (or anyone actually).
Whospoonbill
Also do you know how I can turn up the brightness or is it straight up default % which is
IAmSixNine
Dallas, TX
Sell it and get an SDS100 or Unication G4. An APX is not a device you want to learn and make mistakes on. It can have real world consequences.
