20-006 center loaded telescoping
boroscan30
springboro ohio
I read most of the reviews on the website and most are positive. It seems like a fair price for what I want it it to do. I may take back my 800mhz and exchange it for this one. I'll give it a shot. I know youre going to ask questions so lets see. Ill be using it in my bedroom to pick up all freq. pretty much. It may not do a good job on the 800 but thats ok. Id really like to be able to pick up more HAM and to improve the reception on the ones that I do get. I hope that answers any questions.
I have one of these. You're right about the performance on 800MHz, it doesn't do as well as the RS 800MHz duckie, but I like having it around for monitoring other stuff. Just be extra careful, especially when you've got it fully extended.
nanZor
Upper section anomoly
Old thread, but it still fits the anomoly I found with a brand-new version (2010) and an older one about 10 years old that had rolled under the frig. :)
I was doing some weak-signal VHF work with the antenna sections fully extended - which for me means pulling out the sections from the center loading coil until it reaches a physical stop, and then usually trimming the sections back down starting from the top.
What I found was a very abrupt improvement in signal strength in regards to the very first element to come out of the top of the coil by merely pushing it back down into the coil by a mere fingernail-width! This happens on both my old and new version!
I thought that this abrupt improvement was due to some bad wiper or something else making nothing but a capacitive contact inside - but when tested with a voltmeter, I had continuity between the top and bottom of the coil.
The only way for me to describe this is something similar to turning a tuning-slug too far out of a coil and the circuit goes practically dead, and then springs to life like it should with only a minor adjustment.
You won't notice this affect on strong signals, so you can check for yourself on VHF by using an attenuator and if you have an s-meter you can see an abrupt improvement on the very weak signals. Not a full-scale improvement, but something much faster than you could with the usual fine-tuning of sliding the elements.
Seems like pushing the very first telescopic upper section back down just a slight amount, makes it perform better for those bands that use the upper elements. I don't know what's inside that coil, but if it is truly a coil, I recommend not pulling that top telescopic all the way out to the physical stop. Push it back in 1/16 inch or so.
nd5y
Wichita Falls, TX
It is just a coil on a hollow form so that the top section can slide down through it.
You can unscrew it and see what is inside. Use two crescent wrenches on the little flat sections on the metal ends of the coil or use pliers if you don't care about scratching it.
nanZor
Teardown pics!
I took your advice and tore it down. I even destroyed it to find that if you slide the firstmost top element back down into the coil about half-way, it shorts out the coil and you essentially have a plain telescopic.
No wonder signals improved on vhf-hi without the loading coil! It wasn't necessary.
