2005 Impala
timkilbride
Linn Co Iowa
Orions are VHF(110W/NB) and UHF(100W/NB) combined into one control. The kenwood is a TK-7160. Enjoy.
Tim
lafd55
Albany, NY
Why is the antenna on the front hood when you have an NMO mount on the rear?
mrweather
Looks like a Larsen scanner antenna. Might want to keep it as far away from those high powered Orions.
Rt169Radio
CT
Is the scanner below the am/fm radio a remote head one? How is that Larsen tri-band holding up? It looks quite dirty and roughed up?
lafd55
Albany, NY
I thought that was a dual band VHF/UHF ham antenna. I count 5 antennas so who knows which one goes to what...
b7spectra
EMS Dispatcher
Cobb County, GA
I've got the VHF/UHF Orion's in my truck as well. They are some kick a$$ units! Looks good!
Also, looks like you have the jump box wired to the Orions.
timkilbride
Linn Co Iowa
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.3.4; en-us; DROIDX Build/4.5.1_57_DX8-51) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
newsphotog said:
Looks good! What is the stubby antenna on the driver's rear quarter panel for?
Its a antenna for 800. Not hooked upto anything at the moment.
timkilbride
Linn Co Iowa
I want to keep my scanner antenna away from the 100 watt radios antennas.
timkilbride
Linn Co Iowa
Yes, that is a 996xt installed in the DIN below the am/fm/xm radio. That larsen tri-band antenna has been used since 2006ish. The Iowa winters are hard on antennas. I have a VHF quarter wave that has the ball ate off it! That antenna dates back to 2000.
timkilbride
Linn Co Iowa
Front quarter panel is a larsen tri-band for the 996xt. Top front is a quarter wave VHF for the kenwood tk-7160. Top back is a quarter wave UHF for the Orion. Trunk passenger side a 5/8 wave VHF for the Orion. Trunk driver side is a spare. Rear quarter panel is a 800 not in use.
timkilbride
Linn Co Iowa
Jump box?
pm1072
USA
Glad you got the faceplates for the console. The Orion looks sweet, and so does the Kenwood. Great work Tim!!!! :)
timkilbride
Linn Co Iowa
The jump box isn't wired into the Orions. I have thought about installing a second battery in the trunk for the Orions.
I never have looked up the specs on the Orions, but two of them left on was killing the battery in less then 8 hours, without even TXing. After two jumps(with the jump box in the trunk), I setup ignition sense.
Tim
b7spectra
EMS Dispatcher
Cobb County, GA
I just need to do the ignition sense so mine won't stay on! Even in rx mode only, they do like to drain batteries!
