2005 Jetta Ideas
dtab55
Northern VA
I drive a 2005 Jetta (New Style) and I was wondering if anyone has any ideas about setting up my radios. If you have a jetta also, let me know what you've tried.
I've got to fit...
IC-208H (Ham) w/ Remote
BCD996T
BC 350C
and a cheep @@@ CB
I'm looking at getting the remote for the 996 and then putting that and the ham radio in the trunk with the remotes up front.
Thanks.
DTAB55
silverbk
I have the 2003 Jetta and I went with a trunk mount Spectra high power. The control head sits on top of my ashtray. It blocks the 12v lighter but I bought a triple and mounted it on the passenger side of the hump.
I also put in a Icom 208 rig is under the passenger seat and the control head is stuck to the dash. I don't use it much.
I am considering mounting a VHF Icom 121 in my dash as there's a cd holder where the top half of my double din factory radio used to be. I'll get some pics if you want.
dtab55
Northern VA
Pictures would be great. I have so many ideas that i keep testing but I haven't found one that really works. Thanks.
dtab55
Northern VA
Thanks, thsoe pictures helped alot.. Now I have some ideas, I just have to put it all together. Thanks.
key2_altfire
I drive an Audi A4, which isn't too far off of your Jetta. My only radio is a Kenwood TM-D710A, which is a remote-head radio. The "main" portion of the radio is in the trunk pocket where the CD changer normally goes. My car already had a stout mounting bracket there, which I redrilled for the radio. Short piece of coax goes to a trunk-mount antenna. Hardest part was running the cable from the trunk to the control head in the cockpit, but no heavy lifting involved there.
There is plenty of room in the CD changer pocket for your radios. Oh, I had to run 6 AWG wire from the battery to the trunk to provide the ~25 amps of peak current as listed in my Kenwood's manual. I used the chart here as my guide:
http://www.powerstream.com/Wire_Size.htm
daedalus
Bolivia.NC
Rochound2003 said:
for a scanner antenna you can replace your factory roof stinger with this
http://www.licenseplateantenna.com/
scroll down to bottom of page
Don't know how they work but would make for a cleaner install since you already need a cb and a ham antenna.
That Euro-stinger antenna really got my attention - until I checked the price sheet!
Anybody here actually tried one yet?
CAPTLPOL1
Whoo, for a second their I thought you said you hooked up your 100W Spectra to your cigerette lighter. I see you say the access was blocked to it.
