110W VHF and 100W UHF Orion's combined into one control head. Antenna's pictured are a 1/4 wave VHF and 5/8 wave UHF. The UHF antenna has since been changed out to a 1/4 wave UHF to clear the garage door.
Tim
Tim
Any luck with your hole saw.....i use mine 2 times and the blade is junk......drilled maybe 5 holes and been thru 2 cutters...
I, too, run a vhf & uhf into a single Orion head (full key pad). I even believe they are better than the Motorola equipment I used to run!
You buy that for Lish? Or get rid of your Impala?
That is nice and clean. Did she impose a limit on how many radios you can put in the Uplander?
Good Job,looks like you took your time
