I second Jim. If there is not a spare grommet you can find, use a feed through for something already there. Brake cables, wiring harness, steering etc. Here's what I do. Stay away from the small thick ones. Find a larger one. Poke at it and see feels like could be easily punctured with an awl or something. Then get a stiff wire (coat hanger or welding rod), sharpen the end to a point and tape the wire to it with black tape. Nice clean tight wraps. Poke the wire through the rubber. Before you go around to pull it through, lube the tape wrap and wire. I use simple green 'cuz it's always on the truck. When you pull it will go through the rubber like butter and the hole will be the smallest and mostly self-sealing.
