2011-2021 Jeep Grand Cherokee?
Prospect62
20 year member
Oneida County, NY
Anyone here install a remote-mount mobile in 2011-2021 Grand Cherokee or similar? I'm looking to put an XG-75M in my 2021 Grand Cherokee and let me tell you, there really isn't any room for anything in this vehicle. I could stick the remote head on the dashboard I guess. I had pondered tucking it into the driver's side corner of the dash so when sitting in the driver's seat it would be to my left. But I'd really rather have it down on the console where I'm used to radios being mounted.
Anyway, just looking for ideas and to see if anyone has been down this road with this particular platform of vehicle.
nokones
Sun City West, AZ
I assume that your battery is under the front passenger seat, correct? I would consider mounting the Control head on either side of the console and the radio under driver's seat. If the battery is under the passenger seat, at least that will be convenient, but don't ground the radio/control head to the battery. The seat belt or seat anchor points are excellent chassis grounding points.
Prospect62
20 year member
Oneida County, NY
I haven’t, but I’ve seen examples where mounts by RAM and LIDO were in use.
The LIDO mount came in CLUTCH. It's not my favorite way to mount a commercial radio but in this vehicle platform, your options are very limited.
Excellent suggestion I never would have known about otherwise. I owe ya one.
Prospect62
20 year member
Oneida County, NY
My GC had a RAM mount for multiple heads. When I got it a single head was in the cubby in front of the shifter. XTL deck under seat.
I considered the cubby but the Harris CH-721 barely fit without interfering with the shifter. Plus I didn't want to lose the functionality of the cubby. I like the way this LIDO mount works and how well it's built. The perfectionist in me isn't completely happy with the looks of it, but like I said options are limited in this vehicle. It's a very nice product, adapted very easily to the CH-721 and will absolutely work.
slowmover
Fort Worth
Don’t know how rough-ride may affect, but in big truck would have added “a stand” to keep it more rigid against vertical motions. Some wood with foam atop and Sorbothane on dash. (Weight of device holds this in place).
One can crank RAM fairly hard, but 3-point eventually wins the day in my experience. Tire pressure also contributes. Across a rough lot holding my 8” GPS against movement was SOP. (Fingers on dash and using thumb as brace).
FWIW, I think it looks good.
Prospect62
20 year member
Oneida County, NY
So far so good. Been over the railroad tracks a few times, hit some big bumps and it's pretty solid. I cranked that thing down pretty good, and the control head is surprisingly light. We will see how it holds up.
