televiper75
Hearing Henderson Co. SO doing what sounds like inter-agency ops on TG: 51664 - seems to be relays to the EMS dispatcher.
Hearing storm related traffic on TGID 10128. Sounds like Burke Co. EMS. Maybe an admin channel. Not 100% sure though.
Draf
Heard some type of surveillance operation on TG #10368, anyone have any ideas?
That's an impressive ear you have on you.
Great catch. Added it to the database.
Happy Monitoring
Marshall KE4ZNR
Picked up tgid# 568 on Viper moments ago, the voice and lingo sounds like a NCSHP dispatcher.
Standard talkgroups are spaced out in multiples of 16 for Type II trunked systems. If a talkgroup is altered for a patch, multiselect, encryption, emergency, etc, then a status bit is added. In this case...it doesn't make sense unless there's a chance you misread or your scanner didn't decode the status bit properly.
This time, you would notice that it's a status bit of +8, which per the link below, means DES encryption is utilized. This isn't the case though, because you were able to hear the conversation. Do a little reading on the link below and that might explain things better.
Motorola Type II - Wikipedia, the free encyclopedia
What kind of scanner are you using? Some scanners have the ability to ignore the status bit so regardless of the alteration, it still displays the original/base talkgroup.
Just picked up tgid # 20192 on VIPER - radio check. However, based on similarity of other TGID's, I wonder if it is part of the "NC Office of State Fire Marshal Talkgroups"?
When monitoring the Rowan County VIPER site on my trusty BC246T (analog of course), in the search mode I get a LOT of what sounds like control channel noise on various talk groups. Is this going to be a routine thing until the switch to digital?
Caught another surveillance op on TG #3984 digital, didn't sound like SHP training, radio IDs also affiliated with TG #3968, Any ideas Marshall? Thanks
What you are hearing are the digital voice talkgroups. The 246t can't decode the 1s & 0s that make up the digital voice talkgroup vocoder so it just passes it along as "noise".
Thanks Marshall! The one thing that confuses me though is that the display is showing the talkgroups in even numbers multiple of 16. Is that just all the scanner knows to default to or what?
