2012 Honda CR-V Acc Port
Colton25
I would use the ignition sense but all my radios are in the trunk, plus I have handheld chargers in the trunk so I would just rather the whole fuse panel be on the ignition, and I'm so going to throw a Charge-Guard in while I'm at it.
I'd add:
It's a whole hell of a lot easier to use the ignition sense leads on the radio. They draw very little current, and it would negate the need for the relay.
On the other hand, if you leave your car unattended for long periods of time, it's nice to have a positive way of disconnecting the power completely. I usually just pull my main fuse if I am leaving my truck for more than a week.
Colton25
Hopefully I can get this project started soon, I'll be sure to do a install post when I get everything dialed in.
I am a lineman for the county.
Sweet. I love seeing well thought out installs.
Taking your time, planing it out and getting all your materials staged ahead of time really makes a big difference. Just pay close attention to making sure all your connections are not only good electrically, but good mechanically. Spend time making sure the wire routing is the way you want it. Cover everything with split loom to help it blend it with the stock cables. When you are done, it's possible to make it almost invisible.
Good luck!
