scannerowner
The different sites have different CCs. There are many sites in the areas of the Troops. Talkpair is just suggesting the nearest site for you to listen to that would be beneficial to you.
Testing on the Avalon (Livingston Co) tower 028 ongoing; ID 20205 on 170.5125. Strong signal in Chillicothe on the GRE PSR500 rubber ducky, roughly 12 miles away.
The Livingston County agencies have received a few MOSWIN radios and determing how to deploy them (beside PSAPs).
Joe
troop A was testing today....picked them up on the 197 in house.... 171.51250 CC& 171.26250 CC were coming through loud and clear...
PRO 106
PRO 197
Yeah didn't recognize the Town...I looked in the DB and they use 154.905 on several sites.
First question - on what frequency are you hearing any converstation? You can look up on RR to determine which tower you are hearing. My guess is that the tech is right - they just aren't done yet.Maybe you can help me then, what do you think it wrong with the Winston Site. I'm less than 10 miles from the site and not recieving a strong enough signal even when I'm away from the interference issues I have. I have talked to a source that says it's not "built out" yet, and I'm seeing that they just recieved a license on other frequencies yesterday. My source also says the techs will be working on it to get it online by the end of the month.
My other guess is that they are busting their behinds to get the whole system on-line & fully operational by the end of the year, when narrow-banding is required. Without MOSWIN, I don't know how MSHP would comply.
Therefore, keep monitoring. I think you'll be hearing progressively more activity in the next couple of months.
I've been told all MSHP Chargers came with the MOWSIN radios, and that low-band will be removed after MOSWIN is functional. One would assume for interoperability purposes that "functional" means state-wide (or at the end of the year - whichever comes first). Other patrol cars would probably have old out/new in at the same appointment.
Joe
I'm monitoring the Winston Site, not much luck on solid strength of signal when only 10.5 miles away... Not sure why???
Picking up a new site for my area this evening.
Pro96com shows it as 1CE with a tower ID of 329 with a control channel of 171.38750 and an alternate of 169.66250.
The database here shows this as New Hope in Lincoln County which is north of my location here in St. Louis. The database also has the CC and the Alternates reversed from what I'm seeing.
Signal is good and even my 996XT gets this site. Usually I need the sensitivity of a PSR600 for these distant Moswin sites.
No voice traffic and no voice channels logged at all.
Give it some time, it will improve. Other sites have started off like this where the signal was weak in places it shouldn't be. The Branson site came online at the beginning of April, but the signal was weak until around the middle of May.
Sites often start off with the CC and Alt CC (or a Voice Channel) reversed initially but will flip around for the permanent configuration.
