I'm only 10.5 miles away from the site, it may be alignment then. I know it's not conditions. It has started as a poor signal and I'm guessing will get better as the techs finish building it out...
Have you ever been able to decode the CC data using something like Pro96com on the Winston site?
It's very possible you are getting a CC from a whole other site several counties away although it seems you are using an indoor antenna so the chances are slim it is from a far away site.
Or you may have some interference or desense issues going on that is killing the front end of your radio.
I'm only about that distance (maybe 12 miles) from an 800 MHz site for the St. Louis City PD.
I only get one bar if lucky with an outdoor antenna like a discone. I must use a 12 element yagi to get enough signal from that site.
Then there is a site in St. Charles county that is even closer to my location. I can barely copy that site. They aim the antennas on the tower nearest my location towards the county or city center and that is not my direction. So I get a very low signal level from that site even though I'm only a few miles distance the way the crow flies.
I don't know what type of antennas the MOSWIN sites are using.
Does anyone have any info on site antennas for the system?
Or is it a mix of omni and directional antennas depending on the site?
If they are directional (I suspect many sites may be), then some users may be screwed if the aim is not directed towards them.
Of course there should be a site that does aim your direction if the nearest site does not.
