I recently bought a 2013 Malibu and after a few weeks of not having any radios or scanners in my car and it driving me nuts, I took the plunge.
I don't have pictures of the trunk lid liner removal but it was simply removing the plastic rivets and the plastic handle used to close the trunk. After finding an open area between the cross members, I found the center and made my mark and then used the 3/4" NMO hole drill bit and made my hole.
Then I installed the NMO mount and secured it across the inside of the trunk then ran the end of the coax down the right side trunk tube which I was lucky to be hollow. The wire then came out along the right side of the trunk and fished towards the rear seat. The trunk lid liner was reattached.
The rear seat was lifted to gain access to the wire.
I then removed the two bolts holding the back of the center console and the two screws from inside the console to give me a little bit of wiggle room if needed. I then removed the back of the center console which was held on by snaps. Then, after much cursing and bloodshed, I fished the coax under the carpet to the center console.
I located a free area inside the console where I wanted the coax, future coaxes if needed and a power cable to be ran and used a 1" step bit and made my hole. I then applied a 1" plastic grommet and cleaned up the plastic shavings. The center console screws and bolts were reinstalled. The coax was fished through the grommet.
The rear seat was reinstalled. The antenna, Larsen Special (150/450/800 MHz) installed and open trunk clearance verified.
I currently have a GRE PSR500 connected to the coax so I can set it in the cup holder and then put it in the center console when not in use. I am still deciding if I want to try to install my PSR600 or keep the PSR500 and run an audio cable from the scanner to the Aux In port of the Malibu.
