2016 Winnebago Via Portable Rack Install
TailGator911
Fairborn, OH
#1
Making ready for a summer journey to Alaska in our Winnebago Via and I have lots of room on floor up to dash for a center console radio box install and looking for recommendations for a place that makes portable racks for vehicles. I am wanting to mount 4 radios in a portable rack system that can be easily removed (ideally with a handle on top) and taken outside or secured in hidden compartment while on excursions. I am going to have it professionally installed and wired with applicable antennas on the roof. I would maybe like the rack inside a handsome wood enclosure that will sit on the floor tilted up for easy viewing of the radios. (SDS200, BCD536HP, BC980SSB, Icom IC-2730A) Willing to make a weekend of it if anyone can suggest a professional installer within 500mi of Dayton, Ohio. Thanks!
JD
kf4anc
W3AWF
Chester County, PA
#2
Honestly, I would give Centre Communications in Bellefonte, PA. There a good bit from you however, this sounds like it’s right up the alley of Carl and his team of installers.
TailGator911
Fairborn, OH
#3
Thanks! I'll look them up on Monday. If it's anywhere close to the Hershey chocolate factory and theme park, I will probably be forced to drive there at gunpoint. ;)
JD
kf4anc
#4
Personally I would have them mounted permanently in your location. Then have a false panel made to match that u can just pop on to cover up.... if someone is going to rob your rig they will go through everything... invisible and hard to get out is the only way
Sent from my SM-G950W using Tapatalk
TailGator911
Fairborn, OH
#6
JSTARS03! That is almost exactly what I am looking for! I want it for 4 mobile rigs (SDS200, BCD536HP, BC980SSB, Icom IC-2730A) - and 3 HTs (SDS100, TRX-1, YAESU FT-2DR) and it looks like I can customize it and layer it and tilt it the way I want with the handhelds on top. Shouldn't be too difficult to possibly enclose it in a wood cabinet. Attach a luggage handle on top. I think I can work with this - thanks a million there, JSTARS03!
Man I just love this place!
JD
kf4anc
